Identiying genuine military issue
I won some bids on Ebay recently that included a khaki military pistol belt (I want to use this as part of a B.O.B). The seller told me that it was the "exact same belt as issued to the U.S. military except without the tags" and is made by a U.S. gov't contracter. The buckle has markings "ITW NEXUS" and "Nx-1".
Is this item genuine military issue? I thought all current issue items came with identifying tags?
Also the terminating ends of this nylon belt are little frayed can I heat it with a cigarrette or lighter to "seal" the strands?
Thanks for your suggestions an comments.
ITW Nexus is the manufacturer of the plastic buckle, which means nothing. Some of the pistol belts used to have metal hooks, now they are switching to a large plastic buckle, like a fastex. It could be issue, but when I see "military issue", I tend to stay away. It's usually made by the lowest bidder. If you have something really stout to carry on a belt, that may be a nice belt, but you could probably get aftermarket stuff that's better.
Anything of military issue will have a "National Stock Number, NSN" somewhere on the label. The format for such is XXX-00-XXX-XXXX or XXX-01-XXX-XXXX. Without this number, it is not a sure thing that it is an issue item. If the tags are missing on new items, it may mean a factory second of an issue type item that did not meet government specifications so was sold into the civilian market.
Bruce Woodbury
Former Army Logistics Officer
Bruce, is there a data base we can use to see what products have a NSN? How bout a data base to see what the criteria are for any given product...ie all flashlights must light to 3' after 2 hours, or all knives must not corrode after 10 mins exposure to salt h2o, or all watches must be accurate to x mins/ month at 10 degrees C....that sort of thing... TIA
There is a database but is classified "FOUO" (For Official Use Only). This database only gives you the National Stock Number and a brief description. It sometimes gives you restriction codes as to who can order it, etc. It is not available to the public. A description of the item would have to come from the service and responsible agency within that service who decided the military needed to stock it.
Bruce
