- Jan 15, 2007
splitting the nasty gnarly rounds ... and if you don't want to use wedges ... you ought to consider trying the Fiskars IsoCore 8 lb. maul. It is everything it claims to be as far as absorbing handle shock and blasting wood apart without getting stuck. At first I did not care for the balance as it was much more front heavy then my traditional 8 lb. maul with wood handle. Once I adapted to that and learned to get accurate with the round house swing it became an amazing bludgeon splitter.
I deliberately split a Y round in the center of the Y just to see if I could. I think it was the 5th swing that blew it apart as I needed to cut through the bark and chip away some of the knot before it got in far enough to force the issue. I definitely prefer a chopping block with it because if you hit hard enough to guarantee a split sometimes you are going through the piece with a lot of momentum left.
The bit sharpens up pretty quickly as the profile is right but the edge is dulled--maybe for safety in shipping. The angle is wider than a traditional maul which prevents it from getting stuck. With a sharpened edge, it doesn't bounce--it bites till it opens a split. Clearly Fiskars did a lot of homework to get that angle just right. So just put an edge on it, get the feel of it, then blast away.
