I'm a failure with the Sharp Maker
SirGeod
BANNED
So while I was cleaning my Ultra-Fine and Fine rods for my sharp maker I absolutely cleared off the red marks off the ends and I can't tell the two apart :o can anyone aid me in identifying which grit is which so I don't muck up my edges? Any help would be greatly appreciated
Well my UF's will arrive later today but for now I can suggest seeing which one scratches your fingernail more (alternately a penny should also work for the test).
Get them all good and clean with a recommended cleaner then use them. The UF rods will be smoother, to a degree, than the fine rods.
Just took a closer look at the rods and the UF rods are about 2mm longer than the fine rods. That's pretty definitive.
Maybe my imagination, but my UF seems heavier than the fine.
It is.
Even though the UF rods are 2 mm longer as I stated above... they weigh 1.80 oz. The shorter fine rods weighed in at 1.83 oz.
Swipe each one with a blade three times and see which one removes the most metal? The ones with less should be the UF rods?
Not sure fool-proof, but some of the solutions posted here make more sense to try first.
Although i have never removed the red marks, I marked the Fine rods ends with a black sharpie. Easy to identify and no way of washing it off.
I don't know if you got an actual answer yet. The ends of my extra fine are slightly smoother than the fine rods.
On a side note, I don't have the UF stones (yet) I just use the sones that came with the sharpmaker and finish with a good stropping on a leather belt.
Can anyone confirm that those UF stones will make a world of difference?
I don't know about "world of a difference" but to me they definitely make a difference. Some people are happy with the sharpness they get from the fine rods. To me the UF rods are totally worth it and would recommend them to anyone that has a sharpmaker.
My fine and extra fine stones appear to be the exact the same length.
Maybe you could mark the ends with a file mark or a little hack saw cut.
