My first attempt came to a halt after my wife caught me trying to start the fire on our small backyard. Her concern wasn't the fire but the possibility of a receiving a fine since our county has been on a burn-ban for a while. Since I do not know when or if I will be able to finish the challenge, I want to share my progress and what I've learned so far so that others can use these skills and hopefully complete the challenge. Here's my story so far:
Inventory:
- I began by removing my left arm at the elbow. I was really committed ok? My only concern here is that it doesn't seem to be growing back as I thought.
- My second step was to collect the tinder, kindling and wood which is a lot harder than I thought with only one hand. I chose old wood pieces about 3 to 4 inches on diameter. I used crushed pine needles as tinder and planned to reinforce the fire with pieces of dried pine sap to make it last longer and increase my chances of success.
- Batoning: Let's be real here... what are the odds that you will run into a flat or self standing piece of wood it the wild? SLIM at best! My solution to this problem was to place one piece of wood on the ground and place a second one on top of it perpendicularly forming a T shape. This lifts the first piece high enough off the ground to allow for a swift strike with the knife which will either split/break the piece of wood or wedge the knife into it to continue swinging the knife with the piece attached.
Here I can also recommend using old-almost-rotten wood which splits into pieces much easier with every strike. The drier, the better!
- Striking the steel: I developed two methods for this. The first one was to raise the firesteel with a piece of wood and press down with my foot. This allows for control, accuracy and lifts the steel off the ground. A second idea involves using fibers or jute twine to tie a piece of wood and the firesteel together by twisting the firesteel. This secures the firesteel to the wood and allows for more control and accuracy. Although you still have to use your foot, this makes it much easier that the first method.
That's as far as I made it. Really now all that is left is the ignition but since we had some rain today I am hoping that they will lift the burn ban. Otherwise I might just have to drive about an hour away to another county without a ban. In that case I will start where I left off and post the results. If not, good luck! and I hope this small tutorial can help you win the prize!
