Im ordering A Coote grinder any suggestions?
AJ1
Well im finnally going to get a decent quality grinder, ive been looking and looking and from what ive read on the forums here, the Coote grinder seems like the best for the money. I thought about the grizzly but i dont think i would like it as much. my father is an electrician so im gonna be able to get a good motor for a good price. 2 hp. variable speed hopefully. also i think ill get the 10 in. contact wheel and maybe the small wheel, i think its 15/16" ??? do you guys who already have a coote have any suggestions ? or is there anything good or bad that you think i should know? well thank you very much.
Aaron G.
What do these look like? How much do they usually run? Been thinking about getting a grinder and from a previous thread decided that a belt grinder would be better then a wheel. Where you getting it?
Michael
Hey, Aaron, let us know how it turns out. I talked with Norman a couple of weeks ago and his grinders seem like a lot of tool for the money (230 and up).
I'd also be interested in hearing about motor choice and prices, as I'm considering buying a Coote grinder as well...
Tom
Click here for Grohmann and Marble's knives.
This was posted on a previous post by:
RHINOKNIVES, If you call Mr. Coote he will send you a packet with information on his grinders.
contact normam coote (360)437-0366 pacific time. he also owns a bed & breakfast so if the lady that awnsers the phone says something like that you have the right place.
I think you might want to think about that 10" wheel. It is substantially more difficult to "get in the groove" with a 10" wheel than with an 8" wheel. I'd suggest you might want to start slow with an 8" smooth wheel. If you later want to go to a 10-incher the 8 will still find its uses.
With a good motor, I think the Coote ought to give you good service. One nice thing about it is that there is small wheel attachment available, which is almost indespensible in knifemaking.
Jerry Hossom
www.hossom.com
[This message has been edited by GaKnife (edited 12-02-2000).]
I have both wheels the 10" and the 15/16".
They work great. The small wheel is great for doing finger grooves and tight spots. A must if your doing a mirror polish. Be sure to have Norm set up the grinder for the small wheel BEFORE he ships it out to you. The 10" is a little harder to start out with but it runs really smooth. Be sure to run the small wheel at a low speed. This is a good value for the money
First off, id like to thank you guys for giving me some feedback, i don't really know any other makers, so this forum has been a huge help to me.
and I think i will go with the 8" for now. thanks for the suggestion.
Aaron G.
the coote is the most for the money i know of. used mine for three years. the only problem was my fault. i ran the thing over 1800fpm and the rubber started to seperate on the contact wheel. i got the 10" and then desided i didn't like hollow grinds. if you just like flats & convex he has one without a contact wheel as far as the small wheel assemble go's imo its to much of a pain to switch back &forth. i use a forum flex shaft with 3/4" sanding bands and can use it for many other things.
Laurence Segal www.RHINOKNIVES.com
The only grinder in my shop is a Coote. I use the wheel to help profile, and for heavy stock removal. I use the flat platten (backed with graphite tape) to grind my blades. I use the slack belt for handles etc...
The Coote is a very good value. If i had to do it over again, i would get a 1.5 or 2 horse power motor. Make sure you get a 3 stage pulley set up.
I put my motor on a hinged base so speed changes are quick.
I didnt know there was a small wheel attachement for it, ill look into that.
Final note, its not as smooth as a Bader, but for the $ its a good grinder.
"Never hit a man unless you must, but if you must, knock him down" Teddy Roosevelt.
www.lameyknives.com
AJ1,
I'm ordering another one for our shop next week...
It's a good workhorse of a grinder for the $$$...You should get many years of use out of it...
The small wheel attachment, while clever, is not the same as on a Bader...Having to swap parts out and adjust the grinder to change over is not very productive IMO...
Go with the 8 inch wheel and don't forget to make up a belt cover for safety...
Running Dog
Running Dog Knife Company
<A HREF="mailto:
runningdog@dog.com">
runningdog@dog.com</A>
www.runningdogknife.bigstep.com
I've also got a Coote with a 10" wheel and love it!
I have it hooked up to a 5 Hp motor (I've been talkin' to Larry Harley too darn much!) & a 3 step pulley....I weigh in over #300 and I DARE anybody to bog it down, 'cause I sure can't!
BTW, if you order it with the 8" you can run the 10" by drilling a new set of holes further down on the arms, or just ask Norm if he'll do it when he builds it...
I have a cooteI first got a 10 inch
and had a hard time learning to grind on it
here the wheel was coming lose
go with the 8 inch wheel and about
the small wheel attachment,save your money
you can only run the small wheel for a minute tops with out it heating up
it is made from plastic and i meltd mine
making finger groves.
I had to send my ten inch back
because of the wheel and the axle that
the wheel runs on was runing out.
Norm gave me a hard time when I returned it
put we got thing straighted out.
I ran into the same problem with the small 15/16" wheel. Mine melted also and got sloppy. I called Norm and was cordial. He had me send it back and he replaced the Delrin with aluminum. (No charge)Works like a charm. Just keep it at a slow speed, thats all. It is really for finish work, definetly not a hogger. I run mine at 65 on my speed dial. which means with a 10" wheel it is running at 650rpm. Stays cool and works fine within it's specs.
RHankins Available knives
http://albums.photopoint.com/j/AlbumList?u=205453
AJ1 norm as been great to work with, also i took the cover off the top idler wheel and use it for profiling my rhino patterns. i was useing super flex hermes belts and from convex work they were streching out and running off the wheels. i called norm with a idea for a tentioning device. he made it and set it to me no charge! also guys it lessons the vibartion on the whole machine.
