I'm still here
Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
Some of you knew, some didn't. On Tuesday I had surgery. I had a neuroendocrine tumor at the tip of my pancreas. That isn't such a big deal. It was found by coincidence from some normal tests last fall.
The surgery went smoothly, and they found no surprises. However, since it was so solid and attached, they took the tip of the pancreas with it (an expected possibility). They also took the largest nymph node near the tumor - the spleen (also a possibility). The will biopsy the heck out of them but don't expect anything to be there. I woke up feeling fine and still feel good. No post op issues at all. I un-hooked the leg compression machine and got out of bed this morning, cleaned up, got dressed, hooked everything back up, and am sitting in the chair checking my emails and the forums.
The only issue is they are trying to figure why I have a raised WBC. It may just be my body reacting to the surgery, or some other issue. They can't find a thing wrong with me, though. Lungs and heart are perfect, blood is fine except the WBC, urinalysis is great, no fever, pain, etc. I have a great doctor and she won't just let it go with a wait and see attitude. She is also not one to just prescribe an antibiotic unless she knows what it is treating. They are running some more blood work and giving me some IV electrolyte fluids.
I retired ten days ago and after a few weeks' recuperation should be back in the shop getting it up and working. One problem (a good problem) is that the shop is piled with woodworking and jeweler's tools and equipment that I just inherited from a friend who passed away and an eviction cleanout. There will be a HUGH yard sale this spring. I'll post about it when I am getting ready, as some of the folks within a days drive may want to come. To fellow bladesmiths, I will probably give a lot of stuff away.
I'll keep you chaps updated as things progress.
Glad to hear everything went well, looking forward to seeing new projects in the shop once you fully recover.
Yeah, I'm excited to be able to finally get in the shop pretty much every day. I plan on finding all sorts of things I have and didn't know where it was, things I have an didn't know I even had, and eventually find if there is really a floor under all that stuff. Mostly I want to finish the new grinder room. It will be wonderful when done. This time it will be one-and-done, with no, "I'll do that later".
I plan on moving the welding equipment to the old shop and making it a HT and welding shop. I'll leave a grinder out there for shaping pieces to weld, cleanup after welding or HT, and such, but the knifemaking and machine shop will all be in the new shop.
If The Good Lord grants me another 20 years of shop time, I probably will never have to buy steel or wood (but I know I will).
Glad it went well for you!
Congrats on successful surgery..... and retirement. - Retirement is GREAT!!! You gonna enjoy it for sure.
So glad it went well Stacey. leukocytosis if fairly common post op. It could be a small infection from the surgery that you wouldn't even notice, or it can also be part of a normal surgical response of your body to the trauma. If its still elevated in a week your doc will probably look for more answers.
From a physical recovery perspective sounds like you are right on track with getting up and moving around. Good luck with the rest of the recovery.
Glad to hear that you’re in the recovery phase. I pray you have a speedy and full recovery.
