I really like the way the compression lock looks and works. From what I see in that link, the compression lock really is strong.You are right it uses the liner to lock, but does it in a different way than a traditional liner lock.
From Spyderco's edge-u-cation:
"COMPRESSION LOCK A lock mechanism that uses a leaf-like spring from a split liner in the handle to wedge laterally between a ramp on the blade tang and the stop pin (or anvil pin). Developed and patented by Spyderco, it provides extreme lock strength and ease of use."
http://www.spyderco.com/edge-u-cation/index.php?item=23
So basically instead of the liner just butting up against the end of the blade tang like a traditional liner lock, the compression lock liner is wedged between the back of the blade tang and the stop pin.
And best feature over a liner lock is its on the proper side of the handle.
The worst feature is that it isn't on more Spyderco knives.
