For a while I had been wondering about Linux and after reading the threads about Windows Vista I decided to take a look about what's available. I found Ubuntu LInux, now with a graphical installer and plenty of info on the Web, even some interesting sites in Spanish.
So I decided to try Ubuntu 6.06 which seems stable and is said to have "Long Term Support".
In Windows I installed a torrent client (utorrent) so that I could easily download the 700 MB ISO file, it took about 4.5 hours in my 512 Kbps connection, then I burned the Installation CD with CDBurnerXP (which I've had for a while for backup purposes).
The CD also works as a Live CD which allows for looking around a little before installing to the hard drive, the live use is much too slow to be usable but it can be started in "Safe Graphics Mode" which is OK. the hard disk installation can be done by double clicking the Install icon on the live CD desktop.
The installation itself is simple but it does required some knowledge, specially if you want to keep Windows and be able to choose operating system on startup. I looked around several Ubuntu sites, forums and Wikis to get things clear and to decide on such things as disk partition size, etc.
I wanted to use three disk partitions for Ubuntu (system, swap and one for files in FAT format to share with Windows) but my disk already had two and the installer only let me make primary partitions so since the maximum number of primary partitions on a disk drive seemes to be four I only made two, one for the system and files and one for the swap, I could probably make and extended partition through Windows but I felt it would be too much trouble, maybe some other day, for now I will just use a flash memory card to transfer files between Windows and Linux.
So I am up and running in Linux, using Firefox 1.5 to make this thread, I have installed my Epson C67 printer (with the C66 driver which was the closest I found and seems to work), I have an old HP parallel port scanner which I likely wont be able to use in Linux (Oh well you can't have everything).
I'm happy with Ubuntu, it initalizes much faster than Windows, it runs fast, it comes with good basic software (OpenOffice, Gimp, Firefox, etc.). I know that I cannot get rid of Windows, but this is cool.
Luis
Luis
