Cliff Stamp
BANNED
- Oct 5, 1998
Website (flash heavy) :
http://zubeng.rghknives.com.tw/
Ref :
http://www.bladeforums.com/forums/showthread.php?t=410637
The knives :
These are high carbon steel blades forged in a very special way, see website for details, which claim to produce solid toughness at a very high hardness. A certified materials lab test shows a consistent edge hardness of 66.5-67.5 HRC.
The bowie weighs 590 grams with static and dynamic balance points of 4.5/10.5 cm in front of the index finger in the grip. The blade is 25 cm long, the overall length is 38 cm. The blade is 5.0 cm wide with a full flat grind which tapers to an edge which is 0.055" thick with a light convex grind of 13/15 degrees.
The hunter/utility blade is 190 g, and has a full distal taper from 0.4 cm to 0.1 cm before the tip. The blade is 10 cm long with an overall length of 20.5 cm. It also has a full flat grind on a 3.4 cm wide blade. The edge is 0.035" thick and ground at 15/17 degrees per side.
These are evaluation pieces so they have cosmetic issues and the edge is only rough sharpened. The should be interesting to work with.
-Cliff
Ref :
The knives :
-Cliff
