The faux hamon as seen on the Imperial Tai Pan was most likely chemically produced by carefully brushing on ferric chloride, or a similar wet etchant. It could also have been applied mechanically though. I've never actually handled the Imperial model, and as I really like Tai Pans, I was curious...
Again, the wavy line is the demarcation, or transition between the inner higher carbon stainless and the outer, softer lower carbon layers of Damascus that are laminated on. It would etch darker because of the higher carbon content.
I don't believe the factory took the steel, and hand painted enchant on the edge to make an artificial line.
The whole blade is etched, and the color differences are due to the different carbon contents of the different steels.
So the whole blade likely gets the ferric chloride. No real reason to be carefully brushing it on.
You could, if you wanted to, make a fake hamon line that way, if you wanted.
I've done it on mono carbon steel. Of course, it does not really look like a real hamon line.
I've also made a Damascus looking patterns on steel by applying acidic substances in layers and for varying times.
If you took the Tia Pan and polished all the dark layer off, you would still be able to see the wavy line it you examined the steel closely. Because you have Damascus forge welded in a layer over the top of the stainless mono steel core. It is an actual physical line where the two steels meet.
Now, I've not seen the imperial Tai Pan made, but I have seen the same process done to custom layered knives, including stainless/carbon steel combos, stainless and Damascus combos. I've also seen the process on actual hamons.
If you bought one of the Imperial Tai Pans and polished it up, removing the grey etched color, you could recreate jt simply by replying dipping the whole blade in the acid etching solution, and get the same color differences., including the wavy line.
Again, I don't think there is a guy hand painting and developing that line with hand work. It is already there, and just revealed with a soak in the echant.
