thknives
KnifeMaker
- Jul 9, 1999
Hey folks,
Just wanted to share something with you. For those of you that use the higher end ceramic belts & coated abraisives, like 3M Regaloy or also the trizac belts:
Those belts tend to glace over if one does not use enough pressure to fracture the grit and makes them perform like a dull belt then.
A solution to this is that you can refracture the grit with an old carbide lathe bit. One needs to be carefull while doing that, so as not to groove the belt. This opens the belt and makes it cut as like new. I can consitantley grind at least 4 - 6 5" blades after doing this.
Belt manufacturs have also noticed this and came out just reacently with a belt dresser. It looks like the dressers that are used for stone grinding wheels. They are avaliable for different grit ranges. Have any of you ever used one of those dressers? Here is a link http://www.desmond-stephan.com/beltbrassive_dressers.html
