- Apr 27, 1999
I was helping my wife to assemble a display at a home improvement store the other night and was using my Victorinox Adventurer SAK with 3.25" 420HC blade. It zipped through boxes and plastic banding just fine until I accidently tried to cut through some steel. On one of the boxes there was a heavy 1" box staple (made from something like 1/8" wide my 1/16" thick steel). I didn't see it and tried several times to cut through it right at a bend where the staple material was probably cold work hardened. I really wiped the edge on my knife.
I could still get the knife to cut boxes and straps when I applied enough force, but polypropylene packing tape was just driving me crazy. If I applied real force or used the tip I could cut it, but I wanted to cut it neatly while gripping the tape with one hand. With a dull edge the tape would partly cut and partly tear, often it would get stuck to itself. I usually have at least a couple razor sharp knives on me so being stuck with only one dull one was maddening. The store did not have any demo hones sitting around that I could use.
OK, here's my question. What do you use to perk up an edge like this if you don't want to buy anything or damage anything in the store?
What I did first was to steel the edge on some metal shelf framing. That only helped a touch. Then I stropped on some various plastics, wood, and fiber materials. That helped just a little more. Finally I went to the ceramic tile section and stropped and honed on the back of some scrap tiles. That got me to the point where I could get the packing tape to cut fairly easily.
Do you have any better ideas?
