Abrahms that is. I used (and abused) my serrated black coated model this past weekend while building a fence in my backyard. Let me tell you, this is one solid knife. I used it for everything from cutting the strapping on pallets of lumber and cement to opening cement bags to cutting through sod (and rocks and hard Georgia clay) around the postholes. It got wet concrete, mud, rocks (and just about anything else I encountered) jammed between the liners/scales on a regular basis. With nothing more than a goodly whack against a 4"x4" post or the wheelbarrow the dirt and debris came loose and I could close it and slip it back into my pocket.
At no time did it fail to lock or stay locked. There was not even a hint of lock failure under moderate twisting and severe fouling of the mechanism.
The *only* damage from all of this abuse was severe wear to the black coating on the blade. This tool has been used and you can tell - but only by the cosmetics. The lock is still solid (I'm talking Sebenza-like) and the liner engages in the first 1/3 of the tang just like when it was new in the box.
I wanted this knife as a user and it has far exceeded my expectations so far.
Kudos to Mr. Bloch and Mr. Ralph for an excellent design and outstanding execution*.
Jon Edwards
* For the record that I had, upon first receiving the knife, ground the exposed liner down. It would easily disengage using a "white knuckle" grip. Once that was done I was unable to induce lock failure under any circumstances.
Jon Edwards
