When making a standard chef knife I can get 2ish maybe 3 AEB-L or 52100 knife’s out of a 2x72 36 grit Cubitron 984F belts. All grinding post HT. I just did the same knife out of MagnaCut and I went through 3 36 grit belts and an 80 grit getting it to near final geometry.
I know the belts are on their way out when the blade starts to get small flats. That is, they wouldn’t grind a full flat on the blade. It would take small bites, regardless of pressure. Put on a new belt and they would grind the whole blade again for a while.
Any recommendations for belts, procedure, etc for grinding a MagnaCut blade? I would like to continue to use the steel but what I’m doing seems inefficient.
Thanks!
Thanks!
