In the field (HI Villager and GH Bhojpure)
I recently got back from a ten day camp with a group of five other adults and 32 teenagers between 15 - 18 yrs of age, conducted on a property between Cobar and Louth, NW New South Wales. While there I had a chance to do some work with a pair of khukuri's, a Villager from Himalayan Imports and a Bhojpure from Ghurka House.
On both khukuri's I had done some initial re-working of the handles, grinding the top off the butt-cap so it had a 'tear-drop' shaped profile as I found that the top would dig into my hand during use.
One of the main tasks was to trim and limb out several Currajong trees that surrounded the farmhouse. I have been told that the Currajong is similar to the Sequoia tree, with wood a little harder than pine. Both khukuri's performed very well at this. Using the Villager was a real joy, as it is quite light and easy to manoeuvre, using moderate force I was easily able to cut through branches up to 1.5cm (about half an inch) in diameter with one chop, and larger branches about twice this size with no more than three hits.
The Bhojpure, being about 3 inches longer and significantly heavier was not as quick to use but due to the extra length and weight, using full arm swings and a lot of force I was able to make diagonal cuts through limbs up to 4cm (just under 2in) in diameter with a single cut.
On both of the khukuri's I was using a solid grip, with my hand placed towards the back of the handle, I found a few spots on the Bhojpure where I will need to make a few more changes to the top of the butt-cap and one spot where the area between the first and second knuckle on my little finger rested as it was starting to create a 'hot-spot'.
The edge's of both khukuri's showed no sign of ware and still retained a very sharp edge.
The second main task was to butcher several animals.
PEASE NOTE: The animals involved, a young goat and two kangaroos, were shot for food and killed as quickly and as humanely as possible, I took the opportunity to try out these knives. They were not killed for the sole purpose of testing a knife.
I didn't have either of the khukuri's with me while doing the initial skinning and gutting of the goat, so we used the saw blade on my Leatherman supertool to section the carcase which worked very nicely.
Once back at camp I used the villager as a cleaver to cut the feet off the goat legs, the bones were about 1cm in diameter and I was cutting into a hardwood cutting board. The bones cut quite easily and on only one did I have to use more than one swing. The edge showed a small amount of ware in places and it took a few minutes with a pocket steel to bring the edge back.
I had the Bhojpure with me when I shot the two roo's (one a large male and the other a smaller female).
After skinning and gutting the carcases were sectioned, once at the base of the tail and then again about halfway along the spine.
In sectioning the kangaroos, the large male had a tail about 13cm (4.5 in) in diameter and the smaller roo about 6cm (2.5in), roo tails are very tough, with a very dense bone, sinue and muscle layering. To be blunt, most people use either a bush saw or a full size axe (usually taking 2 or 3 chops to cut through them), which is why I'm so impressed with the way this khukuri performed, doing the same job with only 5 solid hits.
After cutting off both tails and through the spines I found that the edge of the Bhojpure was badly chipped and dented, the largest chip is around 2mm deep and 3mm wide. I was not to surprised as due to time (it was getting dark) I was cutting straight through solid bone rather than finding and cutting through the spaces between vertebrae.
In spite of the damage to the edge I am very happy with the way the Bhojpure performed and once I have taken a few pictures (which I will try and post) I will work the dings out of it with a stone and return it to use.
Andre
Thank you for the review Andre.
Did you have a chance to use one of the khukuris in the skinning operations? I have wondered how they would do, but have not had a chance to use one in that capacity. That seems to be one use where the curve of the blade might be a detriment. Yet they do have a good belly on the front part of the blade. What kind of knife did you end up using for skinning?
Howard,
I did'nt use the khukuri's for skinning, part of the process was to get the kids involved and under the direction of myself and the other adults the kids got to help, either skinning or assisting, either way they got their hands dirty.
I was using a locally available brand knife,
an Excalibur 'Tracker'. I don't know much about them, exept that they are made in Japan and have 440c steel blades.
Andre
Thanks for using English measurements.We never adopted Frog talk.
Hey ghostsix,
What can I say, I grew up with metric but because of shooting and scale modelling I can work just as well in imperial.
Andre
Andre,
Thanks for the great feedback. I've never used a Khukuri on bone (although I think I should get some from the butcher shop to do some tests with - city folk, got to hate us). Could you send me/post some pictures of all of the action?
Thanks,
Craig.
[This message has been edited by Craig Gottlieb (edited 20 July 1999).]
I've never made it to Australia, Andre, but it sounds interesting to say the least.
Yangdu does a little butchering with a 15 inch AK. It is mostly chickens but she sometimes buys bones from a steer or cow and chops them up for soup. So far the knife is holding up okay.
Uncle Bill
[This message has been edited by Bill Martino (edited 20 July 1999).]
Bill,
Well, if you ever get down here let me know.
Over the past few years we have found that for the kids (99% are city kids) on this camp, the experiance of helping to skin, gut and butcher an animal, then a day later of cooking and eating the meat that they helped process has had a huge benefit.
Interestingly, the girls seem to handle the blood and guts part better than the boys. Especially the boys who like to appear tough before hand, nothing brings 'em down to earth faster than a whiff of an opened gut cavity.
Andre
[This message has been edited by Andre Simpson (edited 20 July 1999).]
Andre, I remember that smell very well and I will admit I never did like it much -- then or now.
Uncle Bill
Andre: thanks for testing the bhojpure on the roo tail. I don't know if I asked you already, but if you have pics, can you post them? I'm not morbid, just curious to see.
Craig, I have not got my photo's developed yet, and they only show the khukuri's, no photo's of them in action.
Mainly because some of the kids are a bit sensitive to whats going on and we have found that it's bad form to be taking photo's. Also you get some realy strange looks when you pick them up after being developed.
Marcus; I usually don't do anything with them, we take them off so that when moving the carcase around you dont have 3 feet of tail waving everywhere.
I have been told that roo tail stew is very good.
Andre
Marcus,the last time I was in Aussie,An abo froze the tail,used it for a murder weapon, and eat the evidence.This was about 1987.It was in the papers.I kid you not.
ghost, your stories should go into a book -- ghosties believe it or not. You would put Ripley out of business.
Uncle Bill
This is a little off topic but the best story I have ever heard came from my old man.
He was working around a small town in the Northern Territory with a geological survey team about 30 years ago when one of the local Aboriginies, for reasons unknown, stole the (full) night-soil cart, and tried to escape town with it.
Half way across the only bridge in or out of town he somehow managed to roll the cart, spilling its contents across the bridge and himself.
Needless to say he was easy to track down.
Andre
