Inconel?
I remember that ATS34 is a turbine steel for jet engines -inconel has similar applications.
Anyone know if this stuff can be hardened for use as a knife blade? I know it has a lot of nickel in it. -It's just out of curiousity...
Inconel is a family of stainless steel that is used primarily in high heat applications - like steam generators and other pressure vessels.
It has high nickel content, but it can't be heat treated. It would be a poor choice for cutlery.
Tom is right.
It is a high nickel material.
It is tougher than nails to machine also.
For those making dasmascus... if you find it in thin sheet you can use it for a nickel replacemant in dasmascus.:D
I spent a lot of hours welding on Inconel during my welding career. It is used in acid/and high temp applictions as stated. We used it a lot around hydrofloric acid applications and it was also hight temp at the same time. Have made several rings out of Inconel nuts in my younger days.
