Ok embarrassing to day but the other night I had a few too many at my neighbors, and came home to sharpen my Gayle Bradley M4.
I guess I wasn’t at my best because I started at 15 degrees reprofiling it from the 20 it was at... somehow through different stone thicknesses and me not using a collar stop on my edge pro and being over served by my neighbor
,by the time I got to 1200 I was at 8 degrees
Anyway I’ve always gone from higher to lower angles not lower to higher I imagine I will be grinding into the apex just flipping a heavy burr back and forth, lots of weakened steel and ripping carbides out. On the edge pro I’m thinking about setting my belt grinder to 17 degrees( I have it set basically like a ken onion worksharp belt grinding set up, I can move my 2x42 belt sander from 0-90 degrees then I use a flat that is a 4x4 right off to the side and to get flat at transfer the 90 degree flat onto the belt sander set at an angle it is running 1800 spfm with 60 grit orange blaze norton so I’m not concerned about burning the edge) and grinding it out then taking the 2 degrees off back down to 15 on the edge pro . Advisable ? Not ?
Any advice ?
Any advice ?
