Induction heater for HT
Hello,
Would such a modified induction cooker as seen in the Yt video be of any good for HT?
ttp://www.youtube.com/watch?v=7CDFxZwfQpE
TY
DST
They can be made to work for forging, but I don't know that they'd work for heat treating. Not sure how you could acheive accurate temperature control over an area as large as a blade.
--nathan
Grant Sarver of OCP makes induction forges, but from all I've read I don't think they'd work for heat treat. They'd be cool for forging blades though....
Mass produced chisels are induction hardened. However, they are done on a conveyor belt traveling by the coils, maybe stopping briefly.
Some interesting things happen using induction heating. First, the variables for getting consistent heating change. Part shape, travel speed past/through the coil, and the power to the coil become the variables to sort out and control. A way to measure temperature is important too, but temperature is the result of the above variables. The chisels travel past the coil at a fairly constant rate, and have essentially the same geometry, which allows this to be an automated hardening process. Oh, and they're all made of the same steel too. If you can control these variable carefully, it could be viable. I've read some people love the forges, but they don't try to heat treat with them, and the coil size limits using them to weld damascus as well.
