...it didn't fair well in ankerson's cutting test: http://www.bladeforums.com/forums/showthread.php/793481-Ranking-of-Steels-in-Categories-based-on-Edge-Retention-cutting-5-8-quot-rope.
Ranking above all the "standard" factory steels in his very narrow and specific testing (not that that's a bad thing) doesn't really seem like "not faring well" to me. If pure edge-holding is what a person needs, INFI's probably not the very best choice.
It's silly that so many folks seem to think small blades should "only" be crazy-hard and wear-resistant, and big blades should "only" be insanely tough and easy to sharpen. There are several steels that can give a great balance of toughness and strength, hold an edge well, and not be ridiculously hard or "chippy" - in knives big or small.
Or if you want to stay in the Busse camp, just use SR101 (52100). I prefer it to INFI for small blades and ain't too bad for biggen's either.![]()
I'm going to leave that one alone.True. The Scrapivore is a great blade if you don't find the prybar end uncomfortable when using it as a knife.
SR101 . . . check!It is also helpful that the company will replace this knife of said steel if it ever fails.
Camp Tramp, Howling Rat, Ratweiler, Taliwacker . . . check!On top of that, this steel is highly coveted both for its collectibility and resale value.
There is no such thing as the perfect steel or knife. All steels will cut when needed, but not all steels will be able to cut and do everything else without chipping or breaking. I want a small knife that won't fail if I ever need it to do more than slice. It is also helpful that the company will replace this knife of said steel if it ever fails. On top of that, this steel is highly coveted both for its collectibility and resale value. This is why I both use and collect small Busse knives with INFI steel. Just saying.![]()
There's a guy that posts in Gossman's sub-forum who's used his 3 inch 154cm blade to baton kindling for his home. It's tough, stainless, and will hold it's edge longer than INFI all in a 1/8" stock .
What impresses me more than Jerry Busse's alloys is his genius at heat-treating them. I mean, nobody gets more out of S7 than Jerry does. And that's not just my opinion . . . it's Mike Stewart's opinion as well.
Toughness doesn't apply much to small blades since they can't chop.
I don't think it's silly, just a reflection on how people use their knives.
Believe me, I hear you loud and clear! Maybe you could talk Tom Krein into doing one of his regrinds on a Howling Rat. He could make a slicer out of a boat anchor if you know what I mean . . .That's why I use SR101 as well. Good steel with great heat treat. Only issue I have with bussekin really is one of geometry. Not every knife needs to be thick and not every knife needs an edge that can chop through concrete. An SR101 blade with a thin edge at 3/32" stock thickness and about a 4-5" blade, fully convexed and with a gradual belly going most of the length of the blade would be my dream knife.
