- May 30, 2009
how does infi compare to s30v or s3v or cpm M4? tell a rookie about infi? thanks kids!
Eric aka Knif3buy3r!
Matti S.,
Good question! We have explored this very question. Powdered metallurgy can offer some very strong benefits in certain ares of knife performance. However, it is not possible to take the same analysis from a smelted steel and transfer it to a powdered construct and achieve an improvement. Carbide dispersion is very good and can therefore greatly affect the amounts of carbide formers that are included in the mix. If we wanted to achieve the same level of performance as INFI in some areas, the analysis of the PM would look nothing like that of INFI.
Thanks,
Jerry
Abstract:
The effect of nitrogen on mechanical properties is the result of interstitial solid solution strengthening by the free nitrogen; precipitation strengthening by aluminum and other nitrides; and grain refinement due to the presence of nitride precipitates.
Nitrogen absorbed during steelmaking results in interstitial solid solution strengthening and grain refinement, both of which increase hardness.
who invented infi and what was original purpose for it??
The ability to remove small dents without having to reprofile the edge is pretty amazing at the hardness INFI is heat treated to. The corrosion resistance is very good for a non-stainless steel especially with its strength and toughness.
I think if you do some searches of the old posts in the Busse forum you will find the composition of INFI. It might surprise you.
The heat treat is very extensive. It's called "Transversion Wave" tempering or something. Jerry has said this:
"cryo treatment (-300/320 degrees) which was done in a dry, controlled, atmosphere. This process allows us to take our blades down to temp. over the course of 10 hours hold them at temp. (-300 degrees) for approx 50 hours, and then bring them back up to room temp. over the course of the next 10 hours at which point they receive 3 more, individualized, oven tempers"
INFI is very hard, I believe it's 60 on the mo scale without being brittle. When the edge is very polished, it may loose some of that edge toothy-ness, so you may be push cutting more than a saw motion slicing, but that is a VERY small trade off for the durability and ease of edge maintenance. A very thick bladed infi knife with still out slice a knife of the same thickness made of the CPM steels.
Hey Eric...you came to the right place for info about INFI. In terms of hard use fixed blades, you can't get better than Busse.
Btw...I believe I recognize your email addy from another forum...a green one. Welcome. :thumbup:
If you have any questions I can help with, don't hesitate to hit me here or there.![]()
