Inflatable Pool Help!!!!
Hey Guys...
I've got a 18' X 4' Intex inflatable pool..
Came with a cartridge type filter,, and a goofy as$ed vacume system,, that doesn't work too bad,, but doesn't get the fine particals...
I thought that some of you may have some experience with pools..
This is our first pool...
It's pretty decent considering it's an inflatable...
Ok,, so heres my problem....
I had a lot of little particlas floating around, that just weren't being picked up by the vacume..
In retrospect,, I should have bought a proper vacume system, instead of doing what I did....
Ok,, so someone says to get the fine particals out,, you add whats called FLOC basically a clarifier...
Ok,, so I did that,,and the next day it was sparkling clean,, everything was down on the bottom....
So now how do I get it off the bottom ??
Easy,, borrowed a friends vacume pole, and hose,, worked awesome....
Except!!!
The clarifier goes right through the cartridge filter, and after 10 mins the pool is cloudy again...,, let it settle,, Sparlking,,vacume,,cloudy,, on and on....
Then I read the instructions on the chemical bottle...in Big letters it says:
"Do not Use in Cartridge Filters"...
What's happening is the particals are blowing right through the filter,, and back into the pool....
So without going out and buying a $500.00 pump and sand filter,, how do I get this $hit out of the pool ???
Do I keep vacuming and vacuming,,hoping that the filter will eventually clog enough to capture these particals ??
Anyone know if there is a smaller micron filter cartridge I can use ???
I even thought about wrapping some smaller micro filter paper from my lab onto the cartridge and see if the helps....
Anyone got any ideas ??
Would be much appreciated....
Thanks
Eric....
Hey Guys...
Never mind..
I found the solution....
I'm Draining it....:(
There goes a weeks worth of swimming for the kids..:(
ttyle
Eric....
We had a 14' of the same kind,great pool but a storm came and a limb fell on it a week after we had it so I can't offer much help.
The fun thing about a round pool is if you have 4 adults you can all walk really fast around the edge and it creates a whirlwind,just get it going and drop in the kids and they will spin for hrs lol. My kids loved that pool!
Please make sure you fence it. It's still deep enough for kids to drown in. We had something like that around here this week.
I've read that since they're so easily put up, people aren't thinking about the fenced pool laws and retailers certainly aren't telling you about the danger.
Watch out for rain too. My sister-in-law had an inflatable pool and one weekend it rained quite a bit and it filled up with water pretty quickly and the pool couldn't handle it and one side completely busted, I mean ripped all the way from top to bottom. It looked like a flood took place where the water came pouring out. Just a heads up so this doesn't happen to anyone else.
