The RRF is fantastic, and for your purposes would definitely be a better "fit" than the Sebenza, IMO. I have one (assisted, black "Tacti-Cote" coating, cocobolo inserts), and I have many Sebenzas, and I can tell you
the main pluses for the RRF over the Sebenza.
First, the
handle/grip of the RRF is incredible. It fits the hand way better than the Sebenza, and if you look at the design, you will see that the rear of the scales slopes downward toward the lanyard hole. When you grasp the RRF, you find that this is the perfect fit to the hand shape. :thumbup: In comparison, the scales on the Sebenza are straight. :thumbdn:
Second, you are asking about tactical knives here. No matter what you may hear, I do not consider my Sebenza's as "Tactical". They are hard use work knives, and in fact, Sebenza in zulu means "Work"! They are great for ranch work, camping, chores, etc., but the design, non-assisted opening, and lack of a real choil doesn't suit it to all uses. The
RRF is a tactical that can be used for anything because it
has:
1) an angled thumb-ramp (Sebenza's is flat along the blade spine),
2) additional thumb-ridges over the center of the blade (non-existent on Sebbies), and
3) the assisted version's flipper becomes a choil when the blade locks into place. :thumbup: :thumbup:
Want
more pluses for the RRF? You got it!
The
RRF comes in s30V blade steel with titanium liners, same as sebenza, so the steels are a wash. However, the
Frame lockup on the RRF is better than all of my Sebbies! Granted, it took some flicking open and some pivot lubrication, but now, my assisted opens like lightning, and the frame engagement of the back of the blade is 100% of the beveled frame edge. On my sebbies, you are doing good if you get 50% or more engagement between blade and frame! More frame engagement = stronger lock. Advantage RRF.
Frame release and blade closing are smooth and easy in the RRF. More pressure and a slower close are present in every one of my Sebbies, except maybe my limited annual sebbie, which has a very smooth framelock. Still, compared to non-limited Sebbies, framelock advantage goes to RRF.
The
small details that matter -
RRF.
RRF has a hideaway clip - all that is visible on the outside when the knife is clipped in a pocket is the clip itself. Sebbie - not so much.
The
hideaway clip on the RRF can be moved using torx tools for
tip up or tip down carry, whatever the user prefers. Sebbie - not so much.
Umm RRF comes assisted. Sebbie - not so much.
The titanium handles on the Sebbie scratch when you look at them. The RRF Tacti-Cote is tough as nails.
If you get an RRF with inserts, they are expertly cut and fit the frame with no gaps, and most importantly, are held in with screws! The sebbie annual limited editions, which cost a fortune, are cut to size and then glued on to the frame. There have been reports of these inserts separating from the frame. High temperatures cause adhesives to weaken, and not that I would ever recomend taking a CRK limited annual sebbie on a Tactical Op, but if you did, depending on where you live, I bet temps could get high enough to weaken the adhesive and cause insert separation. That would never be an issue with the RRF thanks to three strong torx screws.
RRF comes standard with dual thumbstuds. That is an expensive option on sebbies. RRF also has a flipper, at least on the assisted versions.
Ok, Im tired of typing but I could go on...In summary, Sebbies are a great work knife, but are not "Tactical" oriented. RRF is probably the most feature-filled 7 inch tactical out there, and is a semi-custom knife. And the best part: a fully bells-and-whistles
RRF is still cheaper than most Sebenzas with no extra features!
