I've done a couple of quickie tests with my new Delica FFG in ZDP-189 and wanted to share and ask questions.
I cut cardboard with the Delica in FFG ZDP plain edge, another Delica in VG-10 SE, and a razor knife with a brand new blade. I wanted to see what the relative differences were between them. Understand that this was very quick; less than 10 minutes per test, very informal, and not at all scientific. Even so, I found it interesting.
For the first test the ZDP blade was basically as from the factory. It had cut paper and shaved hair, and I polished it on a loaded strop for a few minutes to make it sharper. It cut cardboard well, and the FFG blade seemed to have less resistance through cardboard than the saber shape of the VG-10 SE Delica. Cardboard varies a lot and we sometimes get this kind that has a thick profile, but the material itself isn't rigid at all. It's kinda floppy or spongy. So starting a cut on the edge of one of these pieces, the ZDP blade tended to fold the material over, while the SE blade, with a slight pull, began the cut and zipped through it.
Using a penetrating cut first (the tip through the side wall), the FFG ZDP blade was clearly better than the VG-10 SE. The later seemed like it had tons of resistance, which I attribute mostly to the blade profile, as opposed to sharpness or the fact that the VG-10 blade is serrated.
Using a razor knife it became clear that "thin wins" in this test. Clearly the least force used and the easiest to make a cut with. Though the FFG blade was surprisingly close! It really zipped through once it was in; much like the razor knife.
I did two testing sessions over two days and I stropped the ZDP and VG-10 blades in between until they seemed very sharp (hair shaving and cleanly paper slicing). Here's what surprised me the most: The ZDP blade lost it's shaving ability almost instantly. After 5 or 10 feet of cardboard it would *barely* and mean barely shave on day 2. Just catching a hair or two. It still seemed to cut pretty well, but the fine polish was gone.
Now again, the ZDP edge is mostly factory, just with the microbevel stropped to hair shaving levels. I'm trying to figure this out, as I've seen our member here, Unit and his video of slicing the side walls of tires and then shaving arm hair with his ZDP blade (can't remember which one but I think it was a Stretch). I've seen another member here CrimsonTideShooter cut hundreds of slices out of rope with his ZDP blade and then cleanly cut phone book paper.
My guess is that if I fully polished the entire edge, and not just the microbevel, it might do better. But I dunno.
I look forward to comments.
Thanks,
Brian.
Thanks,
Brian.
