Initial impression of 3M "Grinding" belts from Lee Valley
Not coarse enough!
Just got some of the mylar-backed, aluminum oxide grinding belts from Lee Valley (along with a leather sanding belt to replace the one I over stretched) the other day and tried them out last night on my trusty HF 1"x30" sander. Only tried one knife so far (Swamp Rat brand Ratweiler Chopper) and liked the results.
First off, they only cover 180 grit through 1200 grit so they're not for hogging away mammoth amounts of steel nor for turning blade steel into a glossy mirror. A nice closed-coat aluminum oxide, zirconium oxide, or ceramic belt will handle the heavy lifting and you can use a leather belt with compound or a worn 15 micron SiC belt with compound (one that'd otherwise be thrown out - not a fresh one!) for an edge teeming with gleam.
What you do get is a nice array of fast-cutting belts that leave finishes finer than their grits or micron sizes suggest, stay flatter than most cloth-backed belts, and exhibit minimal heat build-up. While not glossy, the finishes left are nice and shiny and quite sharp to the touch (note: not a good idea). Aside from cosmetic reasons, there's very little reason to go higher than the 1200 grit belt. It's very, very nice.
The belts are more expensive than coarser grit sanding belts, but with less curving, less heat, and a finer finish, that's okay by me. Plus, they're more affordable and easier to obtain than Tri-Zact belts.
So, with one knife, I'm quite pleased. Will report more when I get more info.
I like their selection also. I got a variety of their belts, and it's nice to experiment. I haven't had good luck with the leather and CrO yet, I think I'm pushing too hard.
Tried some zirconium belts and the ceramic ones I ordered didn't fit. The 40 grit zirconiums allowed my insanity to go uncontested, but they pummelled me. Hoping to get ceramics that fit the sander soon. I'll probably need them to 'make' the knife I asked about at knifeforums if I can't figure out Matsuhide's website.
Speaking of which, I thinned out my Masahiro MV-H and the performance matches my Suisin wa. Only, my Masahiro MV-H went from being a simple beauty to transforming into a garrish zombie. A garrish zombie that cuts extremely well.
I've got a little 1 x 30 Delta, so I'll be real interested in your experiences here, Tom including any news re ceramic belts.
Ken
The last sentence is the only one to be concerned about, so all appears to be well with the Masahiro. Unless of course you go to sell it :(.
Mike
