Initial thoughts on village Dhankuta
I was one of the buyers who took advantage of Bill's offer on the village Dhankuta khukuris. I won't go into much detail as I just received it today and I am still at school. Running around a chiropractic college with a khukuri in hand isn't recommended, despite BJ Palmer's love for the knife himself!
Also, I don't have any other khuks to compare it to, although I have a customer's CS Gurkha Kukri right now.
So, the sheath appears pretty rough, and it is tight. I'd rather it be tight than loose. The frog looks loose enough to maybe slip off, but we'll see. The sheath is a little loose for the companion knives, but no big deal. Thhese two knives are very little and one will need a better edge. The burnisher is bent, but that probablyt won't matter, although I'm not sure what to do with it, anyway! I'll learn, guys.
The khukuri itself is lighter than I thought it would be, and appears to be a little shorter than advertised, although this may be an optical illusion of sorts! The handle is quite pretty and the endcap and brass collar or whatever (name slips me) are rough but appear very solid. The blade has a roughly made spine and there are many grind lines all over it. The groove is also roughly cut and not straight. What this all adds up to is a rough-looking knife that will be a joy to use! I understand the kamis use very primitive tools to make these knives, and the fact that they can make them at all amazes me. It appears to have good balance, and i will check the aesthetics and edge more closely when I am in a less-conspicuous envirnoment. So far I am very pleased with this knife, and the fact that it is obviously hand made as a TOOL makes it all the better. Fit and finish are nice, but for me it comes down to utility, and so far this looks like a keeper! I'll keep everyone posted. Also, it is outrageously hot and humid here (temps in mid 90's with 85%-95% humidity every day for the last ten days and all this week, it looks), so I will keep everyone posted on how this thing does in the ridiculous summer weather of Iowa!
My Custom Kydex Sheath pagehttp://www.geocities.com/CollegePark/Lab/1298/knifehome.html
Palmer College of Chiropractic
On Two Wheels
With more examination, I can say that the small blade (chakma?) is very well made. Nicely ground with a clean satin finish and seems to have a better edge than I originally thought. I was playing with it in my x-ray positioning class!
Anyway, it seems to be very straight and has a centered edge, and the horn handle is solid feeling. Bill said they were too small to be functional, but on initial guess 9exact measurements to follow) I would say it has a blade slightly over three inches and a handle that is right at 3".
On Two Wheels
Steve
I received a village serupati early last week. My impressions were close to yours. Rough but a cutting machine!! As someone said in another thread, no air pollution,and no noise pollution except for the few words uttered when I miss the point of aim.
However, if you want to have your breath taken away, cast your eyes on a HI khukuri.
Same hand made tools, but a master kami, and what perfection and beauty. Also functional, as I have proven to my self.
How about a inside the waist band kydex sheath for the serupati??
Jim
What? Another knife? Don't you have enough of those things already?
How many does one person need?
Most villagers are pretty ugly but some are okay. I don't think we have had one disappointed customer in all that we sent out. I believe this is because I have prepared them for the shock. Compared to the HI they look pretty scroungy -- but they work!
Uncle Bill
Bill
I didn't mean to imply that my villager is ugly at all. It simply manifests utilitarian functionality. My implication was of the master level craftsmanship and beauty of the HI khukuri.
Nothing else compares!!!!
Jim
Well, more to add on that review, guys. The village Dhankuta has a wavy blade that somehow ends with the point close to the centerline. A bit lumpy and bumpy getting there, though, and the handle may be a bit crokked, but not too bad. The edge isn't quite straight, but again, decent enough. The burnisher is 2" blade with 4" OAL and the other accessory knife is 2.5" blade with 4.5" OAL. Just big enough to be usable.
The Dhankuta itself has a 5" handle, 10.5" blade, and an OAL of 15.25" that I could measure. It is 7/16" thick and 3" wide at its widest point.
I levelled it with a bunch of full power chops and it demolished my wood 4x4. Not quite the penetration then Cold Steel gets, but dang close, and this thing blows huge chunks of wood all over the place!
It is awesome! After this carnage ensued (I'd say I took about 15 full power chops that were straight into the grain, perpindicular to it, and also off-kilter glancing blows) the edge looked no worse for the wear.
The only disconcerting thing is that the endcap is loose now. Is this something I can fix with epoxy or is it more serious and needs to be returned?
On Two Wheels
Hi Chiro:
Epoxy will do the trick. The handle will stay secure even if the buttcap comes completely off.
Uncle Bill
