makariotes, uofaengr & Ajack60 . . . thanks guys (or gals it that is the case!!). My plan is to not remove the old locktite unless it comes off by itself! Does it matter if I loosen up the scales first or the pivot?
It really doesn't matter which screws you remove first, it's not like it's going to fall apart by itself. Even after you remove all the screws, it stays in place. You'll have to give it a nudge to take it apart.
I'm different when it comes to re assembly. I put it back together and tighten/adjust the pivot lastly. In my mind, if I tighten the frame screws first, it trues the frame up and doesn't put undue stress on the pivot.
You're welcome TripleF100! I think I agree with Ajack60, the awesome thing about CRK in general is that they are engineered brilliantly; it's really hard to mess up the procedure when assembling them, unless you're not paying attention.
Uofaengr and Ajack's comments are valid; once you get enough practice you will discover what the easiest way is to put you knife together.
Like I said, I don't own an inkosi, I don't think I ever will since I prefer larger knifes cause my hands are large, and I don't really like small blades, but it looks like a mini 25, I think the pivot is the same as in the 25 so what has been said up to this point I think is solid advice.
It is a good thing CRK includes the tools to service your knife, which means in my mind they actually encourage the user to do it without fear.
If you contact CRK to ask for guidance they will probably tell you exactly how it should be done, or search the stickies in this subforum, there is a wealth of info in there.
Anyway, enjoy the learning process and don't get hung up too much in the details, you will do fine. If you end up messing it up by bending a washer or cross threading a screw, just put it in a Baggie and send it in; it will be fixed for sure.
Congrats on your inkosi! Oh and I forgot, there is a thread called Inkosi, I haven't read it but you might want to check it out, it has 612 entries so you might find some useful info in there too.
Have fun.
