Well, You wanted innards you got innards.
By some odd circumstance, I happen to have some Buck photos (tongue in cheek).
Schrade made Buck 301 bolsters 'innards'. Mid 60s
Keyhole slot hidden bolster pin went in. They hated these in the repair dept. as you have to completely take
the knife apart to change a blade....
Camillus made Buck 303 bolster.
Buck made 303 bolster.
This is the shield(pillar) of a modern Buck with Delrin/Valox scales.
This is a photo of liner with no scale. The holes are NOT metal rivet holes, well the spring rivet is metal. The other holes are PLASTIC rivet holes.
Here you can see where the "head" of the plastic material from the scale is melted flat against the inside of the liner, a small shallow taper into the smaller thru hole makes the head.
Here is Camillus made 307 large stockman, even those had the melted plastic scale rivet heads. Note brass liners.
Here is a Dymondwood 303 which shows it is riveted on. The nickle/silver 'rivets' are hollow on the liner end and are rolled crimped inside the liner.
Note the Valox and Dymondwood share the same liners before being machined to their own specifications.
I know, I know, more than you wanted to know. I am no expert, just showing the "innards" of Buck traditional slipjoint knives
that fell upon my disection table. Keep the discussion 'Traditional'.
300Bucks/ch
