Hallo everybody!
just brainstorming... Could be used a motorcycle brake clamp (old trash), with line and pump lever, to square true forging the ricasso in our blade? like it was the brake disk...changing with two true flat stocks of steel instead of the brake pads.
My concerns are two:
- heat from the blade could be quick transferred to the clamp oil leading to boiling....
altough they are enginereed to withstand red glowing braking disks for competition purpose, for some time before the oil issues.
- maybe the pressure involved is not enough.
I have not presses or surface grinders and consider a true flat and parallel ricasso area the keystone of simmetry of making a knife blade.
Any consideration about this insane idea?
Thank you
Thank you
