Not that Rodrigo needs any help here, but I thought I might post a couple thoughts.
Most integrals (including Rodrigo's) ARE forged down from a solid bar to begin with, but due to the design of this knife and pattern choice (Turkish twist) it required a different approach.
To really maximize a Turkish twist, you need to grind VERY HEAVILY into the billet. If you start a Turkish twist integral with very heavy twisted bars and then draw the blade down from the bolster/guard area, you will lose the super tight, star effect.
Doing it the way he has done, the pattern will be very tight throughout the knife.
In case anyone is questioning the strength of a design like this, keep in mind that damascus blades are all just a series of welded layers. You don't have as much steel manipulation going on POST weld with the things Rodrigo did here with the guard, but I can assure you if you clean your mating surfaces and have proper temps you will have an incredibly strong weld.
The way Rodrigo has approached this will leave the owner with an very strong knife with an AMAZING pattern. :thumbup:
Rodrigo, the bowie above should have definitely been in the "Best of 2007" thread!!! Great stuff!!!
Keep up the great work... you are an amazing talent!!!
:thumbup:
