How To Integrate a shield
Âchillepattada
Hi ,
I'm looking for a tutorial to see how to integrate/insert a shield on a knife handle .
Thanks a lot.
Â
Could you make or obtain a Two-legged Parser? I've seen several videos of one being used online :thumbsup:
You might be better asking in one of the other forums though (or asking Frank or Gary to move this thread) :thumbsup:
Seems to me the trick of the parser is that it rides inside a template. If you had the template it might not much matter what you cut with.
I suppose you could skip the template and trace the shield on the handle and cut very carefully.
There's a lot to be said for not inletting a shield, at my skill level anyway.
The only things I've ever put an inlay or shield on was a couple of CVA kit guns. I wanted barrel wedges, not the barrel pins they came with.
On the kit guns, I put the inlay/shield where I wanted it, went around it with an exacto knife, then carefully carved out inside the line using different exacto blades, checking the fit/depth every so often.
