- Mar 28, 2001
Was heat treating a blade made from 1/4" PG O1 today by my normal method - 3 normalizing/annealing runs, 1550 degree w/soak, quenched in McMaster fast at 130 degrees.
This particular piece of steel is from a unkown source and I've had it sitting in the shop for several years. It was purchased loose in a 1"x8" piece so I don't have any more of it. It was roll printed with manufacturing information, it was only partial but clearly marked as O1.
On this particular blade, the hardness after quench & before tempering was in the mid 40's and I noticed what looked like delamination (I know it's not laminated, just using the term to help describe the cracks) or stress cracks running through the spine, top and bottom of the tang and into the blade edge. No cracking or abnormalities on the flats or blade bevel.
Pretty sure this is not an equipment or process error as I heat treated 4 other blades today with perfect results, just this one failed.
Any thoughts or suggestions? I can post pictures tomorrow if my description isn't clear enough.
