- Jun 14, 2001
I won't post the link here, unless one of the mods tells me it's ok. However, if you type "Sebenza" into the eBay search tool, you will find the following advertisement:
Anybody have more info?
Matthew
Up for auction is a small classic sebenza. For you CRK followers, collectors, and sebenzanistas, Ive got something different for you. First of all, the handle is in near mint condition. Cant say mint because its just been refinished, that being said, nothing else wrong, and does look mint. Two blades come with this auction and both are fitted for this handle and all work, material, and laber was done originally by CRK employees. Both have been cleaned up and will come sharp. One is S30V, tumbled finish, and in excellent shape and condition, rarely used, near mint with slight wear on the anodized thumb lug. What makes this S30V blade unique is that it comes from the first batch of S30V from Crucible. Not the large batch of blades or steel, but from a very small mill run that was for testing of material only, a small sheet of 6 by 8 (memory going bad but it was small). The Vanadium content was 2%, instead of the 4% currently in S30V. CRK only had enough material for 2-3 blades and Crucible changed the make up a little bit later to 3% then again to 4%. More info may be available from CRK or Crucible although many of the folks responsible at Crucible are no longer there. Holds a great edge and will do you well if you decide to use it. The other blade is S90V. Yes, I did say S90V. To my knowledge, only two S90V blades were put into a Sebenza for comparison cutting on cardboard with BG-42 and S30V blades. The other S90V blade is probably in a CRK drawer or it has been round filed, I do not know where it went. This S90V blade has some light surface scratches that can be removed if refinished by CRK, (if they are willing), and is in great shape with slight wear on thumb lug. And, no, dont ask. Thumb lug will need to be removed in order for proper refinishing with a new one inserted afterward. This S90V blade has been finished with a longitudinal satin finish. Neither one of the blades come with a guarantee/date of birth card or CRK box. If you would like more info, feel free to ask and Ill do my best or try CRK.
Matthew
