- Oct 18, 2001
The extras were provided by the customer - ordered from Knife Works.
http://www.knifeworks.com/ratjump-proofmollebackplateforrc-3andrc-4moldedsheath-patentpending.aspx
and
http://www.knifeworks.com/ratmollelockforrc-3andrat-3moldedsheathssheathnotincluded.aspx
I stock TekLoks myself, but this one was provided (and can be ordered through Knife Works as well - http://www.knifeworks.com/rattek-lokformoldedsheath.aspx )
And now for the pic:
(screws have not been installed, but the knife is laid in the appropriate spot)
For those of you that have kydex sheaths already - you will notice that the holes drilled in your sheath will already match up to this carry system.
The slight difference in this sheath is that the holes on both sides are drilled to match both sides. I normally angle the line of holes away from each other to give you a better angle on the various carry options (canted, horizontal, vertical). But this works just fine like it is.
I made up a special jig so that if anyone else wants their sheath drilled this way, it will not be a problem to do it.
Like I said, any of my sheaths will work if you put screws only on one side (above or below the blade, but not both).
If you want screws in the sheath across both sides of the knife, you'll need me to use the special drilling jig.
Let me know if you have any questions!
Thanks for looking!
Dan
and
Thanks for looking!
Dan
