- Sep 5, 2006
KA5601: The Adventure Baconmaker
The Baconmaker -- the more aggressive Adventure blade -- is the ideal knife for hog hunting. Crafted from 1095 cro-van, this beast is built to withstand any abuse and never fail. The hollow ground blade maintains razor sharpness while the knife's overall geometry provides optimum thrusting power, perfect for sticking hogs. The glass-filled nylon handle gives you unmatched control, thanks to an ergonomic multi-position handle that's been finished with our proprietary Adventuregrip texture.
The sheath is specially designed to offer multiple carry options, including MOLLE< and its roomy stuff sack is perfect for hunting necessities like rubber gloves, sharpening utensils, Adventurecord or anything else you need to Own the adventure!
The Piggyback -- the smallest Adventure blade -- cuts like a knife twice its size. It takes no more room than a medium-sized folding knife, and its deep belly shape and short clip point are designed for "unzipping" game. Grip points on the spine allow for even the most delicate work and the knife's simple design makes cleanup a snap.
The Piggyback comes standard with the Potbelly and the Baconmaker.
Features
The Adventure Baconmaker #5601
* Hollow ground 0.188" thick 1095 cro-van steel, Rockwell C 56-58
* Powder-coated for corrosion resistance
* Ergonomic, glass-filled nylon handle with Adventuregrip texturing
* Multiple grip positions for maximum versatility
* Sheath with stuff sack and multiple carry options
* 8' of Adventurecord
The Adventure Piggyback #5599
* Deep belly & short clip point designed specifically for field dressing game
* High carbon stainless steel holds an edge and is corrosion resistant
* Compact design carries anywhere
* Fixed blade with skeleton handle for easy clean-up
Specifications
* Blade Length: 6-5/8"
* Handle Length: 5-1/2"
* Overall Length: 13"
* Weight: 13.4 oz.
* Full Tang
* Made in USA
* Blade Length: 2-3/4"
* Handle Length: 3-1/4"
* Overall Length: 6"
* Made in China
I like the blade shape and handle, overall it looks very usable.
I also like the sheath better than the hard ones that are mostly used for fixed blades today.
