Intrepid Tanto
I'm looking at an awesome Intrepid Tanto on holiday and would appreciate any quick opinions before I take the plunge. Is it 420HC or ATS I can't find this info on Buck's site, I've no doubt it's up to the usual standards but I'm looking for a very hard wearing heavyweight knife. Urgent replies appreciated (I'll probably buy any way!)
Esay, Mate! There is a reason that the Intrepid
is discontinued.
It's a very specialized knife by design.
That said if you need ( or really like) one then
buy all means then.....Hey, you only live life once.
BUY IT:D
I have one & find it to be very good for some jobs
& fairly good for others. Like all do all knives
it will do what you want ....just sometimes with
a bit more effort.
Enjoy:cool:
Tightwad is correct. I've had one for a year now. The primary edge doesn't cut as well as a Sebbie or a Folding Hunter, but it gets the job done. Watch out when you stab. The sharp ridges on the guard can be painful if you stab something hard and they are unforgiving on the front of your index finger unless you're wearing gloves. By design, the tanto point, thick blade, and top edge make it good for prying and cutting things like banding material. I haven't used it for chopping yet. I removed the standard G-10 sides and put a para cord wrap on mine, ala Strider, which makes it much more secure when wet or if you've got winter gloves on. You have to use the tie down for the sheath. If you don't, it unbuttons and the Velcro comes loose on the draw. The 420 steel is ok, but do a search and you'll learn it doesn't take too kindly to salt water. I've never taken mine there, but you will need to lube it now and again or buy some steel wool to remove small patches of rust.
I,ll go for it, my Alpha Hunter does the cutting (superbly) this is for prying/chopping etc. Thanks for the advices
