To bring electrical equipment into confined spaces with potentially explosive atmospheres, you have to make sure that it is certified as intrinsically safe by NEC and/or ATEX. As I understand it, these devices are built in such a way that there is not enough energy in the device to cause an ignition and all contacts (motors, switches, etc.) are not capable of arcing or causing a spark. So, in other words, it's possible, if you bring a normal flashlight into an explosive atmosphere and hit the switch, for the there to be a tiny arc as you close the switch, which could ignite the atmosphere inside the space. It must be certified, being safe but not certfied doesn't help me.
