- Feb 7, 2015
I realize an axe handle is desirable to have the grain tight and running the proper direction. It makes sense a good strong piece of iron wood would have similar grain. So this piece that I'm pointing out with a whole lot of burls is already beginning to crack around the burls. I was planning to epoxy and use Loveless bolts to attach to a gso 4.7 survival knife which will probably end up taking a beating. I showed some other pieces of Ironwood and they seem to be good solid pieces, but this particular piece seems to have a different texture and a different grain structure. My personal GS 06 also included in a photo I've had no trouble with ever. so I'm wondering if this piece will fail in the long run and break piece by piece until it falls apart? Any thoughts gentleman?
Thank you.
Sent from my SM-G930T using Tapatalk
Thank you.
