I've read somewhere that you can TH the tang and not temper it.
If it brakes off after hitting it with a hammer the file is good to make a knife out of
I often hear this same thing when people have some mystery steel....."Heat it to non-magnetic and water quench. If it breaks, it is good knife steel."
That is as far from true as anything can be.
Try this - take a piece of 1X1/4" welding steel from the bin at HF. Heat it to bright red, well past non-magnetic, and quench in water. It will snap like glass if you put it in a vise and hit it with a hammer.
This is A36/1018 steel with less than .30% carbon.....which would not make a knife of any quality at all.
There are spark tests, quench and break tests,....I have even read of people who claim they can lick the steel and tell how much carbon is in it. The truth is that all these type of tests will eliminate some things, but tell little about what you actually have.
Unless you have it analyzed, there is only a guess as to what it is in alloy content.
Just being a file or a rasp will not guarantee suitable steel.
Just being a Nicholson or a Simonds file won't guarantee it either ( they have been made in many different places in anything ranging form W1 to case hardened A36)
Age does not guarantee this either, as case hardening was popular 100+ years ago, when good steel was expensive.
Short summation:
Until one has the experience to ascertain a mystery steel as being useful for knives by how it works and hardens, it is
FAR BETTER to use a known steel.
Until one has the experience and equipment to work higher alloy steels, it is
FAR BETTER to use 1084.
Files and rasps are
FAR BETTER for removing wood and metal that they are for making knives.
Old story:
Years back, at an estate sale of a fellow who made knifes, I bought a nice wooden bin filled with about fifty 18" long pieces of shiny 1.25X1/8" steel. The bin was labeled "Knife Steel". It looked like any good stainless steel from Crucible.
I tried to test it by a quick "heat it and dunk it" hardening, and couldn't get it to harden. I figured it was some high alloy that took a long soak to HT, so I sent a piece to the lab. When the results came back, they had run the test twice to make sure it was right. It had .008% carbon ( that is 1/100th the amount of 1084). It also had 15% nickel, and a lot of chrome.....pretty interesting stuff, but it will never make a knife. As to why it was in a box labeled "Knife Steel", we will never know, but as to whether it will make a knife, I absolutely know...it won't.
Moral of the story - get it tested if you want to know what it is.
