In fact, Dozier will build his knives from A2 for the very reason of toughness for larger, hard use knives, on a custom basis.
I know he'll do the Bowie and the Ranger out of A2, and don't know if he charges extra (if so, it may be trivial, like $20).
Bob hollow grinds his blades. My Ranger is not that thinly ground like the hunting knives are, but you could always ask if he'd do it either flat ground, or hollow with a big (say 10") wheel and leave the final edge profile thickness somewhat thicker right behind the final edge.
Crucible lists A2 as being about twice as tough as D2 with about a 15-20% compromise in edge holding (specified at Rc58/61, kind of a wide range). "Toughness" metric at Crucible is impact toughness via Charpy notch test.
Bob treats D2 to Rc60-61, which is pretty hard, but results in great edge retention. He could pretty easily do A2 to any hardness you wish simply through the tempering process...say maybe Rc57-58. Ask him what he recommends. Example, Chris Reeve does Rc55-57 on his one piece range for reasons of toughness. Just know that edge holding is primarily related to Rockwell hardness, and secondarily but fairly strongly to alloy content. So if you go too soft (I personally think Rc55-57 is a bit soft since A2 is pretty tough already).
So, without much direct experience myself, I'd lean to A2 if you do think the knife will see high impact, chopping kind of use. I suspect that Dozier also has mastered the A2 heat treat like he has D2, and that the edge holding will still be excellent.
[This message has been edited by rdangerer (edited 05-25-2001).]
