tuesday,
You are asking an apples to oranges question.
Your query is like saying, "Other than surgery, is there any use where a scalpel is used, and is it better than other knives?"
Since damascus steel is a knife and sword material, its use and any discussion of superiority would have to be within that field. That is a big topic in itself. There are many who give damascus all sorts of mystic qualities, but the long and short of it is that the material was made to produce a high quality product in a by-gone day when there was no quality control, and metallurgy was non-existent. Besides resistance to breakage ( and that is argued,too) there is no real modern day advantage to damascus beyond the looks.That alone makes it worth the large and costly effort to produce damascus swords and knives.
Damascus steel was developed for swords and knives in the form of wootz steel. It was folded to even out the carbon content, distribute the impurities, and give it more strength. In this day of modern metallurgy and high quality steels, there is no real advantage to damascus ,now. The attractive look, the proof that the smith is capable of producing such a product, and the newer process of mosaic damascus make it a good medium for high end knives. I would venture to guess that nearly 95% of all knives sold over $1000 are made in damascus.
In the modern sense, damascus steel is just a nostalgic term, as the steel called by that name is more properly called "Pattern Welded Steel".
The technique of making tamahagane for authentic Japanese swords is very similar to making the original damascus steel. Tamahagane is still made the same way as it was 700 years ago. Some modern tools, such as power hammers are used, but the process is still the same.
Small amounts of wootz and bulat steel ( the Russian equivalent of wootz) are still produced, but it is quite an intensive process.The sole purpose of this output is the making of wootz knife blades.
Wrought iron was also made by drawing out and folding the iron. This distributed the silicon slag evenly and made a much higher strength steel. With the invention of the Bessemer process and other modern steel making procedures, wrought iron became merely a decorative material with nostalgic attachment. Again, the modern irons and steels are far superior to it. Today, except for recycled old structural wrought iron, the term applies to the look, and not the actual material.
Up until modern gunsmithing techniques and stronger steels, shotgun barrels were made by a wrapping and welding process that produced a strong barrel. The pattern and barrel type was called a "Damascus Shotgun Barrel." Once again, modern and superior materials have replaces it. The pattern is often superimposed on a modern barrel for looks.
Mokume' Gane is a similar material made from non-ferrous materials. Brass, copper, and nickel are common in mokume'. It is even make in platinum and gold for jewelry purposes. Mokume' has a wood grained ( the name means "wood grained metal", in Japanese) look, and is often patterned similar to damascus steel ( ladder, random, raindrop, etc.)
Damascus steel is used occasionally for decorative iron work purposes, but there is no advantage beyond the aesthetics. The high cost of such pieces of work make them for those who purchase what the masses can't afford.
So, instead of trying to have a project with no actual hypothesis to explore, I would suggest that you either pick a different topic, or modify the one on damascus steel to be applies specifically to knives and swords. There could be a lot of experiments on flexibility, cutting ability, edge retention, impact resistance, etc, that would give scientific results as to which is superior, damascus or mono-steel. However, this subject will never be put to rest with a scientific study, as the appeal of damascus is aesthetic and not solely material science.
Stacy E. Apelt, FSA,Scot
