Coldwood said:Doc, I'm really interested in finding what fire straws are all about, but I couldn't open those URLs ("the page cannot be found").
westllen said:cotton balls and put vaseline on them to coat it, then place them in a film canister. works great:thumbup:
I have taken to carrying water proof "flame sticks", made from vaseline soaked cotton packed into drinking straws with both ends melted shut as a form of back up. You can make them whatever length you need, and they can be lit with just the sparks off the lighter, even if the lighter is out of fuel
You can either pull the cotton all the way out and fluff it up for a bigger flame, or I have done it by just pulling out a little bit, fluffy it apart and lighting it. It will then burn the straw like a candle real slowly as the straw melts.
I love these, cause they are practically free to make, you can make them any length that you need to fit inside a kit of hollow handle, and even the smallest spark will set them off and it's water proof virtually completely.
I can't take credit for the idea though, I saw these about 3 years ago in American Survival Guide before it went under.
p.s. these also have no shelf life, I have cut open some that were 3 years old recently, and they lit just like new ones.
also the best way I have found to melt the ends shut is to pinch the straw in a pair of needle nose pliers, then just melt it flush with the pliers good. No burning the fingers this way!!!!!!
You may want to kill me for this, but I forgot to mention that if you use a q-tip as a ramrod to pack the stuff into the straw it goes a lot easier and faster.
Full size straws...use a regular q-tip to stuff, if you want to make really small micro kit ones with those little stirring straws, clip the end of a q-tip. One of the reasons I like these firestarters is the ability to make them any length you might need, but I hardly ever make one above 3-4 inches as that does get hard to fill.
Oh OK...I always have a Zippo to, when I make these fire straws it's for mini and micro "survival" kits, not everyday use. Right now I am working on a neck pouch made out of folded over and sewn 2" elastic strap that holds a small knife, fire straw on one side, and strike-anywhere matches in another straw down the other side, then the whole thing hangs around the neck under a shirt.....Tool and Fire in one nice concealed kit.. always with me.
So how much petroleum jelly do you add to the cotton balls before stuffing them into the straws? Or does it matter?
Just enough to coat it. To much and they are hard to light from a spark.
I like to seal the end the place heavy pj coated cotton in first, then some not coated at all then top it off with more heavy pj coated cotton. to use I slice right down the side of the straw and pull the dry middle cotton out to light. It always starts right away and burns longer with the heavy pj on each end
