First, is there a good forum or other online resource for things like hanging hammers & sledges, etc. so I don't bother you guys with these questions? I'm looking for a good place (if it's here that's great too) to answer things like this:
Does grain orientation differ any with a hammer than an axe? (claw or mechanic/ball peen)
I recently got a whole slew of tools from my dad that have been collecting dust for years. Most of them were his fathers. Specifically, I've been looking for a handle/haft for a Stanley claw hammer that my dad said was his father's. The only weird thing about this Stanley hammer head is that the top of the eye (square, don't know what that style or shape is called) is larger than the bottom of the eye. It isn't larger by much, the top of the eye is 30mm x 16mm and the bottom is 27mm x 14mm. It is Stanley brand and not ground out so I have to believe that was intentional. Is that just to keep the hammer head firmly attached to the haft?
Hope this makes sense: Should I be using a larger wedge (or larger kerf slot) and still trying to profile the outside of the haft to the inside walls of the eye, such that to insert the haft into the head you almost need to pinch the kerf slot closed to get it in there? It is also wider front to back so that must mean I'm supposed to use cross wedges as well as a standard kerf wedge?? So that the the combination of wedges spread the haft out fully to the whole eye??? Should I use wood or metal wedges? This seems fairly advanced to attempt as a second hang, should I get a few other hangs under my belt first or just go for it, buy two handles and plan on screwing up the first one?
This axe forum is a great resource for learning about handles, hanging, grain orientation, etc. but a hammer is clearly not an axe so I don't want to dilute this forum with hammer questions unless its welcome and OK to do so. Thanks.
