- Dec 21, 2017
Hoping to provide some rust protection, but don't have much experience with such a scabbard.
Thanks in advance.
Thanks in advance.
It seems a rather bad idea and design. Leather retains moisture, and the kydex outer skin will slow down or prevent evaporation. A recipe for rust and corrosion.Noob question, why do you want leather liner with a Kydex sheath?
If that's the case, why don't you use rubber or synthetic rubbers?I believe it was originally experimented with with 2 purposes in mind. One was that leather was softer and prevented scratches to the blade. The second was to try to mitigate sheath “rattle” making a kydex sheath silent. You would benefit from silent draw and re-sheath, as well as the added benefit of great kydex retention.
Not all synthetic rubber are made or used to increase friction like natural rubber. Many of them are used to mimic real leather.I would expect a rubber inner sheath to have too much friction and lack durability.
There is a chance that it is not real leather, nothing wrong with that in my opinion. Each material has their use, using it wrong to push the price is nothing but a waste.Just picked up a $500 fixed blade that came with a leather lined scabbard. Oiling the leather was just a thought.
In what particular application?Not all synthetic rubber are made or used to increase friction like natural rubber. Many of them are used to mimic real leather.
Well, I'm the one who suggested, I will put down some:In what particular application?
Neoprene: Waterproof and oil resistance, has low friction, insulation, most notably used in water and swim gear like high "rubber" boots and dry suit. https://en.wikipedia.org/wiki/Neoprene
Bromobutyl rubber: Waterproof and chemical resistance, works in extreme temperature (for human), higher friction (but greatly decrease when oiled), used in for lab equipment and military gear (gas mask, CBRN gloves and boots), still very. https://en.wikipedia.org/wiki/Butyl_rubber
Nitrile: Likewise, waterproof and chemical resistance, works in extreme temperature, low price, used as protective equipment against chemical and radioactive hazard. Some variant are self sealing, used for self sealing tanks. https://en.wikipedia.org/wiki/Nitrile_rubber
Viton (FKM): https://en.wikipedia.org/wiki/FKM (not hard to find these at hardware stores)
All of these are called synthetic rubber, all of them are used to make synthetic leather as well (which is just the molded surface texture to look like leather).
Leather and Kydex have a couple unique qualities when it comes to making a good sheath. They're very stiff so the sheath won't flex and the user won't stab themselves and they're smooth so easy to draw and resheath.Well, I'm the one who suggested, I will put down some:
