Good questions Ad!
Are the Rangers' hafts a stronger design than the Vietnam's because they protrude above the steel? What are the pros and cons of each?
The Ranger Hafts are stronger than the Vietnam Hafts because they are about three times the size. The handle attachment of the Ranger Hawk is a 1 degree drift, where we press the handle down from the top, allowing the tapered handle to match the tapered eye. It is also a period form of handle attachment, and the Ranger Hawks are a period offering.
The Vietnam Hawk, while a bottom-UP attachment, is not weak by any means....we still taper the eye and wedge the handle wood from the top, offering very similar construction. The Vietnam Tomahawk by design however, is too small to support a 1 degree drift method, which is why we press the handle in from the bottom, just as the originals were in the 60's, and then wedge the handle wood in our tapered eye, which we call a "Step Lock". It is extremely strong.
Also, is there a reason why the Rangers and the Vietnam use different steels? What are the pros and cons of the steels?
Yes.....the Ranger Hawks are hand forged from two steels and the Vietnam Hawk is drop forged from one.
The 1060 steel used in the Vietnam Tomahawk is the same steel which Peter LaGana, the original designer and manufacturer, used in the 60's. We are being true to the design.
Both Hawks are made from excellent high carbon spring steels, offering tremendous shock resistance with our heat treating process.
Andy Prisco,
Co-Founder, Manager
American Tomahawk Company
877-557-5200
http://www.americantomahawk.com
