You should use blue loctite on the pivot only. Do not add loctite to any of the handle screws...you will be in a world of trouble. Take a look at the sticky on the top of this forum. It has a ton of great information.
Thanks Rubi, I don't use much now. My first XM didn't need any loctite, this one does. However, that may not be the case when I install the ti pivot, a slight difference in size/shape makes a BIG difference in how a screw fits. We will see.
I used Teflon tape on my Ti pivot screws and it's worked great
Ok - not intentionally trying to be dense but I've read the sticky and didn't see any reference to using Loctite.
Why is it verboten on handle screws?
I will confess that I'm a loctite user, just a teeny little bit. Today, I received my anodized handle screws to match the brown scale. And when I replaced them, I used a very tiny bit on the threads. Blade is well centered and all appears well.
Did this prior to seeing this thread. Now you've gotten me all paranoid. Don't want to screw up my baby.
If you just did it, I would take out your handle screws and clean them off. I think the size of them makes them susceptible to stripping or even breaking if you use blue.
Ok - thanks guys. The loctite hadn't set up yet, so I carefully backed them out and wiped them down and reinstalled. Carefully screwed them down just till they snugged up a bit. Not very tight, just enough. So I think I'm ok.
Learn something new all the time. Appreciate the help!
Joe
