Hey cards, you can send it in and they will take care of it for you, but do you own the sharpmaker? If not I would highly recommend picking one up. You can keep all of your knives scary sharp with very little effort. Great tool.
Yup I own the Sharpmaker and like it but I'm having a little trouble with the tip. Left side of tip is perfect and right side of tip not so perfect.
I dropped it one day and it suffered a little wound. I've been working on it but can't seem to get it to look like the other side. I don't want to risk messing it up so that's why I'm thinking about sending it in for touch up.
Fair enough. Just out of curiosity, do you have the diamond rods? They are pretty much a "must have" for the sharpmaker.
Thinking about sending in my PM2 to Spyderco for a sharpening to clean up the edges. Has anyone done this or do they have a Spa treatment like Buck?
The only time I sent a knife into Spyderco was a Shabaria with $5 return shipping. It came back with a letter that it was "sharpened" but it would not slice paper. Basically it had the same sharpness of when I sent it in. And definitely no spa treatment, this is not Benchmade you know.
No, it's not. If it were then the pm2 would likely be a $200 knife.![]()
...I don't want to risk messing it up so that's why I'm thinking about sending it in for touch up.
If/when needed I plan to send my SE Tasman Salt in to have it sharpened, the combination of two different sized serrations and a hawkbill blade shape is just not worth the hassle to do myself, I'll spring for the $5 for a factory new edge.
I would rather pay $110 for a knife without an option of blade swap, than add $90 for insurance.But maybe then they would offer blade swaps like benchmade does...
Hi John, do you have a sharpmaker? I sharpen my Tasman a couple of times a week on the sm. Nothing to it, and it stays razor sharp. Nothing wrong with sending it off if you like but just be aware that it's really easy to maintain on the sharpmaker. :thumbup:
I do, with the medium and fine rods that it came with...I was going to PM you but I think it would be more useful to have it public to lurkers etc...how do you sharpen the Spyderedge hawkbill on the Sharpmaker?
Well, everyone is going to have a little different technique, but I'm happy to give you a quick rundown of how I do it. As far as serrations go, I just use the corners of the fine stones and sharpen like normal. The only difference is instead of alternating sides I do 3 swipes on the cut side to every 1 on the flat side. I always do this on the 40 degree setting because all I'm really trying to do is add a microbevel. One other thing I change on a serrated blade is when I'm doing the flat side I tilt the knife so I'm hitting the edge at about 5 degrees instead of pulling it straight down at 20. Probably not necessary, but it works for me. All you are really trying to do on the backside is remove any burr. That's really all there is to it. And if any of that sounds like too much trouble then you can always just sharpen it alternating sides exactly like you would a regular knife. That works just fine too.
As far as a HAWKBILL goes, just follow the same recipe but slowly drop the handle as you are pulling down so the edge stays relatively perpendicular to the stone.
One point I will make is that a serrated edge is MUCH easier to maintain than to repair. I keep my SM set up in the kitchen and I always give my serrated edges about a 30 second touchup after any major usage. In the long run it ends up being less work than letting them get really dull and then spending 15 minutes repairing the edge...with the added bonus that you've always got a razor sharp knife.![]()
