is low hrc better?
coping
BANNED
im thinking 55 hardness could be a batter steel than 62 when out for a week or 2 due to easyer sharpening on a rock or textured surface, if you loose a sharpener for a 62 hardness are you naffed or can you sharpen it on a rough surface.
If backpacking ultralight, would taking a lower hardness be better if you got like plenty of stone around where you are heading, to save carrying a hundred gramms or so of knife sharpner?
Have any of you tried sharpening different hardness's on natural materials?
coping
Remember that hardness is just a part of the equation, wear resistance plays a lot into sharpenability... 55 might be kind of low
I'd say something like AUS8 would be a good choice for something like you are talking about
The hardness is a minor factor, its the wear resistance that causes the issues. 1095 @ 62 is easy to sharpen, S90V @ 59 is not. This is due to the 9% vanadium in S90V.
If backpacking for only a week I wouldn't carry a sharpener, and wouldn't need one. Chances are the knife is only going to see light duty like opening food packs or slicing some vegetables. Heck, I've backpacked a week before and barely used a knife the entire trip. I know I've gone on multiple day trips without using a knife once.
It would be different if you were stationary camping for a week and needed to chop wood, or were hunting, or were spending months on Continental Divide Trail.
Oh for...., sounds like I got of things to read up on again and more questions lol.
How do you know about a knives wear resistances? Is it different for every hardness of each steel?
Off topic but what kind of work do you do that allows you to take week long breaks?
An archaeologist. Work a few weeks, as long as the particular project lasted, then laid off until the next project started. I had lots of time, and just the right amount of money (none), to spend those down times backpacking and hiking. :)
I also worked at Philmont Scout Ranch for ten years, most in the backcountry.
I think something made of CPM S30V or one of the very wear resistant steels would be better than soft. S30V stays pretty sharp for a very long time even though it can loose a little sharpness. Very tough steel and not crazy hard to sharpen with good stones.
It depends on the steel, with hundreds of steel options you would need to pick one and read its data sheet to get a idea for its performance capabilities.
It's been years since I've been on an extended trip. Don't think my knees would do it now. :(
Nonsence,
Backpacking ultra light can be about 9 kilos to not cost too much, going lighter may cost a few k in gear, shelter even fishing rod, an axe a saw couple blades, the lot fit into 45 litre with maybe an extra 10 litre pack if you chose a sleeping bag material that doesnt stuff down so small :)
Nonsence,
I also have a 'real' job now, and a home, and a family... :D
Sure I'd love to get out more, but I have to make do with squeezing in an hour or two here or there.
If you have a need for sharpening out there in the boonies, just buy a diamond card that you stick in your billfold. The size of a credit card.
DMT Dia-Sharp credit card sized diamond sharpener, Google it.
Sonny
