- Dec 30, 2016
I just bought an official Buck leather sheath for my 110. I wonder, however, if it's too tight. In order to snap the button closed on the sheath, I must force the knife deep into the sheath and the spine of the blade (at the apex where the clip point starts) is pressed down so that the back spring is not flush the way that it normally is flush with the brass bolsters and frame when open or closed. When I pull the knife out I can feel and see the tension on the back spring and blade releasing and coming back to it's normal position.
I'm not too mechanically inclined so I can't figure out if this will adversely affect the tension of the spring over time. I also imagine that getting into and out of my car and other movements of daily life will put even more pressure on the blade and spring. I assume that the leather will eventually stretch and loosen, but in the meantime it will be stored in the sheath with this tension on the spring. Is this something I should worry about, or is it completely normal and harmless to the knife?
edit: This is more a question about the knife and the backspring and less about the sheath.
This is my first post on Blade Forums so I hope I've put this in the proper category. I also searched and couldn't find this question answered before. Thanks for your help.
