- Jul 6, 2011
I know s30v is an awesome steel, but 154cm is also a great steel for a lot less money. Is s30v really worth the extra $$$?
I find S30V to be a finicky steel... it has to be heat treated properly to really excel... Given proper heat treat, I would definitely take S30V over 154CM...
Depends who does the heat treatment. I believe Buck, Strider, Spyderco, and Kershaw have that one down. Benchmade, not so much. CRK runs it a bit soft IMO.I know s30v is an awesome steel, but 154cm is also a great steel for a lot less money. Is s30v really worth the extra $$$?
I like both steels, they both are good all-around type stainless steels, S30V will give you a some better edge holding, but will be a little harder to sharpen as well. Although you can get into S30V for as little as $55ish dollars, Buck vantage pro or mayo Kaala, spyderco native, etc. If you're looking at a certain model that comes in both steels, and the S30V version is way more expensive then, I'd say no, its not worth it because they are similar enough, I'd probably pay an extra $10 - $20 for an S30V upgrade though depending on the knife, for example on the ZT 200.
Is s30v worth the money?
