I saw this post on http://edcforums.com/threads/toothy-vs-polished-edge.106484/ and was wondering if there is any truth to this?
Also (I'm sure to get lots of disagreement on this one) but stropping is the enemy of edge retention depending on what you're cutting. A barber can get away with stropping a razor because all he cuts is hair, but if you were to take a barber's razor and cut cardboard with it you would destroy the edge. You can get a knife just as sharp with a high grit stone as you can a strop, and get a much more stable and refined edge that will last much longer. If stropping gives you the perception that your edge is getting sharper than when you finished with your stones, then you aren't leaving the stones with a well refined edge to begin with. In other words, your work on the stones needs more work. Strops only bend and stress the teeth on an edge, and so they may stand up those teeth and give you the perception that the edge is stronger, but they're making the edge weaker in the process. By comparison, on an equal grit stone you cut the teeth instead of standing them up, and end up with a much stronger refined edge that will last drastically longer regardless of what grit you actually sharpen with.
